-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Help an idiot out ... identify where this line goes (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/692371-help-idiot-out-identify-where-line-goes.html)
ibtisam.jawad 08-02-2012 08:55 PM
I am trying to replace the HCV on my stock 87 Turbo and in doing so I disconnected a vacuum line and have no clue where one end of it goes.
The line that I took out is pictured below.
http://forums.pelicanparts.com/uploa...1343965599.jpg
One end of it (the curved side) goes in the following hole, I believe.
http://forums.pelicanparts.com/uploa...1343965879.jpg
http://forums.pelicanparts.com/uploa...1343965906.jpg
Where does the other end of it go? I have no clue. :confused: By the time I had the HCV off, this thing was completely loose and just fell off. I didn't take a picture of it before. It went from under the intake to some place unknown. Can someone help me identify where the other end goes? I don't know the names of these parts so a picture with this highlighted would help me greatly. I have looked at the following two links but cannot figure out which one this line is:
http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/409105-porsche-951-944-turbo-reference-list.html
VACUUM DIAGRAMS at LINDSEY RACING - Your Porsche Performance Parts Center
Thank you so much for helping me out.
ibtisam.jawad 08-02-2012 10:46 PM
From the 2nd diagram in the link below, is my line the one coming from G and going into H?
http://forums.pelicanparts.com/pacific-northwest-us-wa-id-ut-hi-ak/315326-attn-944-turbo-owners-have-some-time-your-hands.html
mikepellegrini 08-03-2012 07:07 AM
The shape of it, it looks like the one that runs from the cycling valve to the fitting on the bottom of the throttle body.
mueller944s2 08-03-2012 07:26 AM
If you took a pic from farther away, (so we can see where exactly it is), it might help. If we know exactly where to look we can go out to our cars and start looking around.
ibtisam.jawad 08-03-2012 08:23 AM
its not coming from the cycling valve. its a hex looking thing that's below and between the cycling valve and the heater valve toward the back of the engine. picture to follow.
ibtisam.jawad 08-03-2012 09:30 AM
The first picture below shows where one end of the line should be attached. I think this is labeled G on this diagram: http://forums.pelicanparts.com/pacific-northwest-us-wa-id-ut-hi-ak/315326-attn-944-turbo-owners-have-some-time-your-hands.html
http://forums.pelicanparts.com/uploa...1344011209.jpg
The currently connected end goes into the valve pictured below. I believe it is H in the link I mentioned above. The loose end would then go to the throttle body next to B in the same link.
http://forums.pelicanparts.com/uploa...1344011220.jpg
Have I got it right? Can someone please take a picture of their engine bay showing this loose end being routed? Thank you.
ibtisam.jawad 08-03-2012 12:49 PM
It does go to B i.e. below the throttle body. Thanks.
