951s brake swap onto 951
I am looking to swap 951s brakes onto my 951 and vise versa.
my understanding is I will need to swap spindals/rotors and calipers to complete this. am I missing anything? flex lines same? etc |
That Guy
Instead of swapping the spindles, get these adapters..
Racer's Edge -- Racer's Edge Big Brake adapter blocks Rotors and pads also, brake lines are the same.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Location: In a dumpster behind Albertson's in Los Angeles County
Why would you want to put 951 brakes on a 951S?
1989 944 NA Glacier Blue - SOLD IT 1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 081988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG Semper Fi |
If the 951 is an '86 then it's early offset and you've got more stuff to do. If '87+ then you'll be good doing just spindles out.
Rich |
its late style 1987. thanks
In the Fires of Hell.....
Flex lines are not the same between Turbo S and 951 brakes. You would need to swap those with the spindles and such.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
