Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
can you open the TPS
In the process of a throttle body reseal I confirm that the throttle shaft seals are shot. This makes me suspect that some blowby oil may have gotten into the tps housing. How can you safely open this housing to clean. I thought I would just spray it with electronic cleaner.
Any tips on reinstalling the tps to the throttle body.
thanks
quickster
87 951
Old 03-13-2013, 09:34 AM
I have not personally done it but the TPS can be taken apart and reglued back together with silicone or a suitable weather proof glue. Gently use a dremel and cutting wheel to seperate it all in the middle. Note the position of the TPS before removal would be best but you can set it with a volt meter I beleive or do it by ear with throttle open a little then closed.
Old 03-15-2013, 02:01 PM
I have an early 944 na throttle body with tps if you need one.
Old 03-15-2013, 02:02 PM
thanks, i got the throttle body back together and the tps is set and everything is working great so im gonna leave it alone. btw the seals on the throttle body were shot so im glad i did the reseal, did it all make a difference, yes, noticed an increase in throttle response, that and replacing all the vacuum lines the car has more umph
Old 03-15-2013, 02:39 PM
How to repair the TPS.
TPS Repair
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 03-15-2013, 10:14 PM
