There is no substitute..
Hi!
![]() I would like to know what ratio should I expect at: -idle -while good acceleration -while cruising (stay at 14,7.. 14,5.. its good) My car is Lindsey Racing 305 RWHP and 350RWTorque kit with a air/fuel gauge (wideband 02sensor) Thanks.
--Matt I couldn't find the sports car of my dreams, so I built it myself Porsche 951 1988 - More than 305 RWHP & 350 RWTorque |
That Guy
-Warm idle- 14.7
-Accelerating hard on boost... 1-5psi in the mid 13's then at 5+ psi gradually richening to 11.8 at full boost. -Cruise should be 14.7 under vac, as soon as you get into boost it should start to richen.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Ok great. hard on boost is normal then.
I dont remember on idle but I think im not at 14,7. Will get back tomorrow Ill take the car for a couple hours ride. Thanks Techno!
Porsche 944S Club Sport
FRZ951:
-idle It should fluctuate between 14.2 (Rich) to 16.8.1 (Lean) Every ~ 2 seconds. -while good acceleration Vary load dependent between 12.5 (low boost 1 - 4psi) - 13.7 part throttle less than 10% TPs opened. -while cruising (stay at 14,7.. 14,5.. its good) Fluctuates between 13.5 and 14.5 Measured with a wideband... Later...
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
| Tags |
| 944 , air/fuel , porche , ratio |
