Low boost issue, need to know what to do next
I seem to have a hard time making boost. I use to be able to easily get boost and reach almost 2 bar. Lately I'm only able to get to about 1.8 +/- bar (on the car gauge) and it doesn't pull hard. The car revs to red line and I don't think the clutch is slipping.
I pinched the line going to the WG and I'm only getting 1.2 bar (per the gauge). I've been able to visually check the vanes and play of the cold side of the turbo and they seem fine. I had the car leak down and compression checked and it all turned up good, so no problems there. I replaced all the small vacuum lines. I replaced the pop off valve on the J boot. I pulled the waste gate exhaust pipe off and the valve was fully seated though I don't have a tool to pressure test it other than compressed air tank. Not sure its a good idea to use that. I know the OEM gauges are not that acurate, but it is a constant I've been working with. I bought a cycling valve, but have not tried installing that yet since from what I've read if it fails I should only be able to hit 1.2 bar. I have a hard time getting past 1.2bar unless I just floor the throttle, but I can achieve about 1.75-1.8 if ever so briefly before boost falls off. I don't think its a WG issue since Im not making boost with the line pinched - something else would seem to be at play. I'm not sure where to go next? Thanks for any help you all can give. |
heeeeeeeelp
failed wastegate or leak in the intake system. check all of the hoses and clamps, especially the big one just before the throttle body.
Agree that a slow build up of pressure is most likely a leak issue, whether intake or exhaust is 50/50. There's also a chance that the double walled crossover inner pipe has collapsed if you've chopped the throttle while on song.
Well I pulled the intake and have installed to a new CV I had and replaced all hoses running to it just to eliminate it as a variable.
I did pressure test the system from the J boot. The only leak I had came from the Air/Oil separator. But that system should only be under vacuum right? I don't think it would show up as a boost leak since its never under pressure (other than blow by?). I intend to put the system back together and test run it. If the boost doesn't change I will pull the WG and check the crossover with a bore scope to see if it has collapsed. If it hasn't collapsed then It must be the turbo or something electrical. Can a DME produce low boost or difficult boost? I bought a new boost gauge I will install to verify actual boost as well. What is strange is that the car is more or less (maybe a tad less) powerful than before I put the Lindsey 3" exhaust (with cat) on it. Then for several days it felt like a totally different car with great pull. Then is went back to pre exhaust levels. Do these cars have the sophistication to learn new power curves when things are added? Wouldn't think so. |
Well, it's the KLR computer that controls the Cycle Valve, and takes the inputs from the Knock Sensor and such for Turbo health, DME computer is more a Timing, Air Flow and Fuel control device. Still, on again/off again, and the fact that the Exhaust has been disturbed, makes me want to run a Feather across all the Exhaust joints, cold and hot, there's some real growth and shrinkage with 400 degrees.
I had an issue similar to this on my car several years ago. I normally boost 2 bars but would fall off to 1.8 bars above 5500 rpm. The problem was a faulty wastegate. The way I isolated the culprit was to fabricate a blind flange and attach it to the wastegate so no exhaust gases could bypass the turbo. Then I did a test by first accelerating the car to 5500 rpms at no boost. Then I momentarily floored the accelerator. Car leaped ahead as boost jumped way up beyond 2 bars. This proved the wastegate was at fault. Needless to say flooring the accelerator must only be a momentary test else you'll get into trouble quickly. Prior to doing this test I tried pinching off the line to the wastegate. It had no effect on the boost problem.
Sounds like exhaust Leak check Headers and seals.
Vacuum Gauge test -17hg if perfect..., Intake manifold typically leaks at Idle control outlet. Fix (Remove & Tig) Later |
Hi, just wanted to share my experience and ask some questions. Bought the car half a year ago. During the winter did the general maintenance work and started to drive it this spring. Still have done less then 1000 miles. I soon noticed that the factory boost gauge shows the boost of only 1.4 to 1.45 bars and the boost builds up only after 3000 rpm. I brought is to a workshop (not experienced in Porsche's) and asked to look for a problem. They found out the following:
1) the actual boost maximum was 1,55 bars (the factory gauge is showing 0,1 bars less boost than actual) by using other boost gauge, thus still 0,2 bars below the factory specs, 2) they could not identify any leaks in the intake or exhaust pipes (I do not know how they did that test); 3) They put on for a test new Bosch bypass valve and there was no difference in the boost pressure; 4) The boos with disabled factory chip was around 1 bar and they said that his is less then K26/6 turbine should produce (it should be at least 1,5 bar) 5) They think that the issue is with wastegate (worn out spring). 6) They propose to program new chip that would consider the worn out wastegate specifics until permanent solution can be done (e.g. wastegate restoration). One big part of their business is chip-tuning that they say it can be easily done. I am not sure about such solution. I have also sent some info from this forum about dealing with boost issues. If anyone has any further suggestions (especially about wastegate restoration), please feel free to comment. |
a new waste gate is what ... 500 bucks, and the car needs it. a much better solution than chipping it around the problem.
you also might try shimming the waste gate. |
Replace the wastegate. I cannot imagine a shop telling you to chip it if they know the wastegate is bad. Wastegates don't fix themselves.
Which wastegate would you recommend? Lindsay Racing offers single and dual port wastegate. They mention that for dual exhaust wastegate the minimum boost that you can set is 9 psi, that is still higher then the standard maximums boost for turbo (according to clarks garage it should fall to 0,52 bar that is around 7,3 psi at 5800 rpm). Could it be issue or the difference is quite minor. Or should I just use the single port wastegate that is direct replacement for the original? I might chip the car in the future but do not plan aggressive chip or any other significant modifications.
This is an extreme test but I have performed it to ferret out a boost problem on my 951 a few years ago. It proved the problem was indeed the wastegate. My problem was that the boost would fall off to 1.8 bars (from 2.1) once the engine exceeded 5500 rpms at full throttle. I am one who does not throw parts at cars in order to fix a problem. I determine what is wrong and fix only it. It saves money.
The test I did to isolate the wastegate was to fabricate a blind flange which is basically a sheet of metal with only bolt holes in it. The flange is placed at the wastegate exit to the dump pipe to prevent any gas from not going to the turbocharger. Once installed I ran the engine up to 5800 rpms at no boost (light throttle), then momentarily floored it. Car leaped forward like it was hit behind by a semi and the boost gauge nearly broke its needle. Naturally, I immediately let off the gas so I would not damage the engine. It was a radical thing to do but it definitely proved the spring in the wastegate was defective. I should mention that prior to this test I pinched off the control line to the wastegate so that the test totally isolated the wastegate itself. |
Intake-leaks come after the AFM, and will cause too-rich mixtures and stumbling if you're loosing boost on the intake side.
If you're familiar with programming, set up a finite-state machine test-table and determine the pressure-differential at no-boost, zero-boost and any amount of boost for both single & dual-port wastegates with manual-controllers. Then add a 3rd test using dual-port wastegate with electronic-controller w/twin solenoids in push-pull. As for the actual wastegate, the issue is the stock spring is weak and starts opening at 4-5psi in the diaphragm. Over the decades, the spring weakens and opens at 2-3psi. That's weak enough that exhaust pressure alone will open the wastegate at high-RPMs with zero pressure in the diaphragm (wastegate hose clamped shut). That test itself will give a clue if the wastegate's leaking exhaust. It doesn't rule out collapsed wall in the crossover. Lawrence's test is the only definitive way to completely isolate the wastegate for testing. After you've blocked off the wastegate, if you're still having low boost, then most likely it's a turbo problem or collapsed exhaust. On an aside note, people seem to think that big wastegates go along with big power. Strange logic considering that the wastegate's function is to dump exhaust and lower boost. If you're going to try and extract the most power out of your turbo, then you want as little exhaust dumped as possible to maximize boost and power. Just a little clipping at the highest-flow peak to keep it level at the desired boost-level. For example, a turning up boost on a TO4E turbo to go from 300rwhp to 400rwhp required reducing the amount the wastegate opens in the 4000-5000rpm range from 3mm to just 0.5mm. With electronic-controller, it even clamps the wastegate completely shut from 5000rpm onwards to deal with the dropping torque-curve. Some of the ricer guys run completely sealed exhaust with no wastegate, maximum boost is whatever the turbo can do all out. Can hit 40-50psi in its most efficient range and drops off after that. They just size the turbo to match the engine's flow based upon displacement and its RPM range. Then tune the fuel/ignition maps accordingly. A 2.0l 4v engine with 10,000rpm redline can actually flow more air than our 951s and a K26/6 will run out of steam at 4500rpms, even with the wastegate completely closed or no wastegate at all :( |
Thanks for the provided info, Danno. I am thinking of getting new dual port wastegate from LR, with their boost controller ("Boost Enhancer"), new bypass valve and new 3'' exhaust. After that I would chip it but I would go with quite conservative chip with 13 psi at the lower rpm range and at read line dropping to maybe 9 psi (I have K26/6). The workshop gays are saying that generally If I have under 300 crank HP I do not heed 3'' exhaust, but as I plan to put a new one then there is no significant difference in price between 3'' and 2,5'' set-up.
I would appreciate is anyone with experience could comments on the below questions: 1) Do I have to increase the fuel system pressure (I assume, no)? 2) Is there any gain from dual port wastegate combined with LR "boost enhancer" or can I go with their standard rebuilt WG combined with boost enhancer and achieve the same results? 3) Is there any benefit for 3'' exhaust vs 2,5'' exhaust considering the above? 4) Would this set-up be aggressive for the K26/6 turbo/the engine? 5) Is there something else I could/should do considering that the car ill be just used for some Sunday driving and occasional track days? I am not looking for max HP but rather at more mid range HPs. Thanks, any comments and experience is appreciated. |
No need. There's an inverse-function between pressure and total flow. Increasing pressure decreases the maximum volume the fuel-pump can deliver. It's a balancing act, and increasing pressure slightly from 2,5 to 3,0-bar will let you get more from the stock injectors. Up to about 300rwhp with modified programming. The chips must be programmed for a specific fuel-pressure, or have adjustments to allow for mutliple pressures and injector-sizes. 2) Is there any gain from dual port wastegate combined with LR "boost enhancer" or can I go with their standard rebuilt WG combined with boost enhancer and achieve the same results? You won't get any difference in boost-control with single or dual-port wastegate if you use a manual controller. So go with the single-port if you want the LBE. Otherwise dual-port if you plan on getting an electronic controller in the future. The LR is a rebuilt factory wastegate, I prefer using a Deltagate, Tial or HKS. Also do not use flexible vacuum hose for wastegate-control. Use hoses similar to the stiff 15mm hose that Porsche installed. Soft hoses is one common source of fluctuating, variable and dropping boost. The nice thing I like about electronic controllers is programmable boost-curve per gear. That's 3D-mapping like with fuel & ignition. 1st-gear typically has mid-range max-boost of about 12psi with a increase to 15psi by redline. Second-gear has 15psi mid-range max-boost and increase to 18psi by redline. Third/4th/5th-gear has 18psi mid-range max-boost increasing to 20-21psi by redline. The lower-boost in lower-gears act as traction-control and keep the tyres on the chirping-edge of traction for maximum acceleration and control. The rising boost-curve also counteracts the dropping torque-curve to yield a flatter dyno-chart and gives higher peak-HP than torque; a sign of good high-end efficiency. 3) Is there any benefit for 3'' exhaust vs 2,5'' exhaust considering the above? Get the 3,0" as it will allow for future upgrades. I like the SFR 3" exhaust, lightest and highest-quality construction. Get the muffler configured with a slip-fit using posts and springs to mount. Then you can quickly change it out for a straight-pipe at the track. 4) Would this set-up be aggressive for the K26/6 turbo/the engine? Not at all. I've gotten over 320rwhp out of K26/6 with 3" exhaust, larger fuel-pump & injectors, EBC, MAF/MAP, standalone-ECU, etc. Might as well get all the components that will work with future upgrades. 5) Is there something else I could/should do considering that the car ill be just used for some Sunday driving and occasional track days? I am not looking for max HP but rather at more mid range HPs.
Thanks again Danno. Lot of valuable information for me as new 951 owner. I will take a look at the other wastegate options you mentioned. Regarding other to do things some of them are already done before the first track day I will participate next Sunday, like OIL (Bred Penn), brake fluid with increased boiling temperature, EBC yellow pads, tyre balancing, gasoline (I use only 95 or 98 octane), but still some work to do.
Currently the car is at the workshop for upper strut bar instal and as a next thing I plan to change the alignment. Also thinking about changing out koni sport shocks as people with track experience are saying that those do not "work" properly on track and suggest putting on Bilstein's B6. |
Danno, I did little internet research regarding wastegates and have found that many recommend TiAL MVS MV-S V38 for our cars. What is your opinion about that wastegate? Would it be good fit considering the other planned upgrades I mentioned before? I see that I ill need adapters, but considering that I will instal other exhaust system, I should not hurry up with ordering the adapters for the standard system or can I reuse them?
Yes, Tial 38mm wastegate is good unit. Will work well with stock and any upgrades you do in the future. The adapters are available from many sources. Most aftermarket exhaust are configured to use the stock wastegate. So if you get adapters to fit Tial to stock exhaust, it will also work with aftermarket exhaust later.
One big benefit is the exhaust-flow and pressure pushes the valve closed, compared to pushing it open in the stock & LR wastegate. No high-RPM boost-drop due to exhaust pushing the wastegate open. You're outside of the U.S.? Most likely your gas is 95 or 98 MON octane. Similar to U.S. 91-92 gas (RON+MON)/2. You'll want to get a mix that gives you around 101-102 MON octane for safety at the track. With constant full-throttle usage, the engine heats up, the coolant heats up, turbo, etc. This can result in pinging/knocking and quickly burn up & blow headgaskets. Have fun! I'm also doing a trackday on Sunday 1-June at Sears Point. :) |
Good luck at the track! |
| All times are GMT -8. The time now is 07:36 PM. |
