Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
87 turbo low volts
My 87 turbo keeps the needle to the bottom in the voltmeter upon start-up.
The car idles, but I need to rev the engine a few times up to 2000 RPM approx, then the needle in the volt meter will go to almost 14 volts and stay there.
If I shut the engine off and then re-start, it will do the same thing.
I replaced the alternator recently with a rebuilt one because of this condition, but the condition remains.
I re-tightened the alternator belt but it appears pretty tight, no slippage.
I checked the positive wires connecting at the underside of the fuse box, they were tight and clean.
I replaced the positive wire from the battery to the starter and the negative wire from the battery to the back of the engine a while ago since these wires had their insulation dry-rot and falling apart.
Has anyone had a similar condition? where else can I look for grounds or loose connections?
Thank you for your help.
Old 01-23-2014, 08:24 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
DMM needed, Check for Gnd Loops and Noise.
Raulg:
That's a typical reading. Does your dome light dim significantly when at idle. Maybe you also have ground loop issues (subtle but present).
All the cars do. Use a Digital volt meter $10-20 from Harbor Freight or Sears to check all your ground points. Especially your 2ndary circuits, Horn, fog lights, tail lamps, cigarette lighter socket, dash lights, etc. Voltage should be 0.001vdc or less.
That is why grounding circuits (active/passive work when properly installed under the hood) and its noticeable and the 2-8hp dyno number reflect it as well. The 944 GND points are almost identical in all models. Later.
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 01-23-2014, 09:51 PM
Another thing that plagued the 44 line was that the exciter wire for the alternator was taken from the Gauge hook-up, and in line with the Low Voltage Warning Bulb, - lose the Bulb and you lose the exciter, so it takes rpm to pump up the juice. Have a careful look at the Gauge as you first Key On at the Bulb Check cycle. A Ballast Resister was added sometime in the series to cure this, but I have no idea when.
Old 01-30-2014, 04:31 PM
+1. Many Audi's and Porsches of the period need to goose the revs a bit before the alt starts charging. Feel free to check the exciter wire connection but sounds fine.
Old 02-05-2014, 05:10 PM
