Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
porsche wont start
I have 1984 that I bought been my dream car since I was 16. I put a new fuel pump and starter in along with plugs. Amd all its doing is cranking but not starting. The security is not on and have gone through the whole car. Ive checked all the wiring and connections and they are goodnight car only has 25000 on it the ppl I bought it from drove it before it sat for years. Need help figuring out why it wont fire up
Old 03-05-2014, 01:37 PM
Is very busy
TheRedSlantnose's Avatar
The injectors may be clogged, did you check those?
Jason
1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser
1986 944 Turbo (951), 350+hp, Guards Red- Track car
2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver
Old 03-05-2014, 02:28 PM
Air fuel and spark are the holy trinity of starting. Get these three with proper timing and it will start.
Do you have spark?
Can you try to jumper the DME relay to hear the fuel pump running?
Can you check fuel pressure at the rail?
Is the AFM plugged in?
Will it start with starter fluid?
Is the rotor in properly?
Verify the firing order from the distributor to the spark plugs.
How long has it been since it ran?
Have you checked compression on the engine?
When were the timing belt / balance belts last serviced? When and how many miles ago?
Answers to any of these questions will help narrow down your no start issue.
Good luck.
Old 03-06-2014, 04:59 AM
JJK78-951's Avatar
Yup - what Ky914Newbie said! Check also reference sensors... and smacking the fuel injectors with a small wrench to loosen them up as old fuel has probably gummed them up.
John~
2003 996 Turbo... 128K Daily-ish
2000 Accord V6... 275K - 65K motor/trans now given new life!
Old 03-09-2014, 07:30 PM
