Nigel Tufnel Wannabe
Fuel Pump not running...
Just getting done with a rebuild of my 1986 944T engine and wanted to check my fuel pressure before attempting to start. Was wondering if the fuel pump should be running when I turn the key to the "on" position? I have read that the car needs to be cranking over for the pump to turn on. Is that correct?
1986 Porsche 944 Turbo, Sapphire Metallic. Nice restoration. I'm done spending $$$$ on this car. Ha,ha...it'll never end! |
Yes, car needs to be cranking for it to come on. Have someone crank the engine over while you put your ear next to the pump or you could just take off the fuel rail end cap with ball bearing (remove coil wire) and put a hose in there with a gallon jug and crank the motor over and see if if it fills up the jug.
The engine must be turning over to excite the DME Relay to tell the DME to run the fuel pump.
Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
You are correct, you ain't running a carb where you need to fill a bowl before you start turning it over...
dolor et pavor Copyright |
Thanks for the info. All is well with my fuel pump. Good pressure at the fuel rail gauge.
You don't need to start the car (or even turn the key on) to activate the fuel if you jump pins 30 and 87b on the DME relay socket.
Porsche 944S Club Sport
Pix of bypass relay Fuel pump test.
Later...
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
