Porsche 944 Turbo headlight upgrade
I've searched the forum for information on headlight upgrades for a 1987 944 Turbo and couldn't find much and the links that I saw were dated an inactive. Does anyone have any current info on products to use and weather or not this is even possible due to wiring issues etc.
Thanks!!
1987 Porsche 944 Turbo-Guards Red 2001 Kawasaki ZX-12R-Neon Green 1986 Kawasaki 1000R-Red Former Porsche- 1987 Porsche 944-Black |
In the Fires of Hell.....
I put a set of HID's in my 924S race car for our upcoming 24 hour race at Buttonwillow. I just bought a set off of fleabay for like $80, and they came with the H4 lenses and the HID lights/power packs.
For the very limited testing I have done so far they seem to work fine, and are much brighter than the 50W halogens that were on it. The HID's actually draw LESS current than the halogens, so I didn't change any of the wiring.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
HIDs are probably preferred to day but it is very easy to drop in some Hella lamps with replaceable H4 bulbs of higher wattage. Drop in a few relays and your lighting should be much better.
FYI Theres a sticky post at the top of this forum with a link to a post all about headlight upgrades.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
Thanks for the info guys. So the HID's shouldn't cause any wiring issues because it's actually less wattage than the stock bulbs but with the Hella bulbs would they be a problem down the road for the wiring? I'm going to,check that stick post also to see if the answer is there.
1987 Porsche 944 Turbo-Guards Red 2001 Kawasaki ZX-12R-Neon Green 1986 Kawasaki 1000R-Red Former Porsche- 1987 Porsche 944-Black Last edited by motorscuba; 03-30-2014 at 09:58 PM.. |
Couple issues with the factory lights:
To rectify these issues, you can do the following:
With the sharper cut-off, you can get away with higher-power bulbs and not have as much glare as stock. The Iceshark kits came with Narva 90/100w bulbs and with the wiring-upgrade, can put out over 3-5x as much light on the road as the stock configuration. Can't find those bulbs easily, so I prefer to use 70/75w or 80/100w H4 bulbs (no tint allowed). Anything higher ends up sacrificing bulb-life too much. Last edited by DannoXYZ; 04-02-2014 at 04:20 PM.. |
Is very busy
You can do a fixed-light conversion as an option.
Jason 1987 930 Slantnose Cabriolet, 545 hp, Guards Red- Weekend cruiser 1986 944 Turbo (951), 350+hp, Guards Red- Track car 2005 Toyota Tundra SR5 Double Cab 4x4, stock 282 hp, Silver- Daily driver |
Sorry for being out of touch for a while. Danno...that's a pretty involved upgrade but I guess you can't just go straight to the ecodes without doing the other items first. I'll talk to my mechanic about this conversion. Thanks.
Redslantnose....can you give some more info on the fixed-light conversion?
Super Moderator
iceshark used to be the best lighting available for the 944/951. i haven't been researching lighting lately though.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Problem with HID in H4 housings is the filament alignment don't match and you end with a lot of glare. Search for "Daniel Stern" and you'll get a to be of tech info on headlights and upgrades. |
If you're looking for fixed headlights, I'd recommend 924-76's setup:
New GTS headlight conversion kit available soon. I've got a set I've yet to install and its of good quality. |
