Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
944 Tach
Can't get my tach gauge to work. Replaced it with a used one to no avail. Anyone have any recommendations. Thanks. Rod Davis
Old 05-23-2014, 11:51 AM
911tracker85's Avatar
just got my 951 project car started after months of installing a different engine.
my tac does not work either. will be watching this thread.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 05-25-2014, 07:05 AM
The tach is driven by the DME pin#21.
It's a thin green wire with black-stripe.
Use an oscilloscope and probe that wire near the DME.
The signal should look like attached photo.
Trace this wire DME #21 all the way up to the dash-gauge.
It goes through a 4-pin plug; make sure that plug is still connected.
Probe the wire near the dash and verify that it matches the signal transmitted by the DME.
This test will let you know if the signal or wire is bad, or if the tach is bad.
Old 05-25-2014, 02:47 PM
