Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Calipers
Can someone please help me identify what calipers these are on my 944 turbo? I want to replace the rotors. I measured the rotors and they are 304mm x 28mm but can’t find any Porsche model that had this size rotor
Old 10-29-2024, 06:53 PM
Another angle
Old 10-29-2024, 06:55 PM
My car is a 1986 but the original owner changed the front end to the later setup
Old 10-29-2024, 06:56 PM
The calipers are mounted with adapters. I purchased a 304mm x 32mm Turbo S rotor but it seems too thick
Old 10-29-2024, 07:00 PM
The newest of the noobs!
grendiers's Avatar
I have ‘Big Reds’ on the front of my ‘89 car. The dimension between the bottom brake line, and the top fluid nipple, is approximately 7.5”. This is measured from the body of the caliper. Brakes are from either a 93-94 911 turbo (red), or same years of 928 GTS (black). Not exactly sure of the years involved. Measure your caliper, and if it’s the same, I’ll forward part number for rotors.
Old 10-30-2024, 08:27 AM
Thanks for the reply, but for some reason the rotor on my car is only 304mm x 28mm which seems small if the calipers are Big Blacks. I would assume the rotor would be bigger
Old 10-30-2024, 09:58 AM
Rickster
huskerick1's Avatar
I would assume these are the M030 calipers that came on the 88+ Turbo S - same as those on a similar year 928. The big blacks/reds are surely larger...
1989 944 Turbo S - Slate Gray
1989 928 - Slate Gray
2015 Panamera Turbo S
2005 Corvette Z51
2011 Harley Heritage
Old 11-14-2024, 06:57 AM
Rickster
huskerick1's Avatar
There is also a casting number hidden inside near the brake pad ends... hard to see, but it's there.
2005 Corvette Z51
Old 11-14-2024, 06:58 AM
