-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   ran then died --- no start - no spark (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/818786-ran-then-died-no-start-no-spark.html)
911tracker85 07-01-2014 01:08 PM
well.... another sad 'wont start' thread.
read through a lot of similar threads. got a lot of suggestions from knowledgeable 951 folks.
got this car as a project. spent the last several months finishing the installation of a refreshed engine.
replace/upgraded everything. got it running a few weeks ago first try, surprised the heck out of me. after finishing a few minor items, took for it's first drive. initially slow, city driving. got to where I could try to give it some gas. easy in 1st, into 2nd and start to feed the gas. car started picking up, felt boost come on and saw almost 5lb on the boost gauge
then ...nothing
just like flipping a switch.
car will crank like crazy, new battery.
got it back to the shop and started looking around. suspecting something pulled loose since I had just gotten it running.
so far I have:
pulled and had DME tested in another car
verify power to the DME
jumper DME relay
verify fuel pump running, new pump, hoses, filter.
replace reference/speed sensors. (tac in car inop).
used snap-on O scope to verify senors. even verified pulses at the connector to the DME. saw tooth for speed and the TDC pulse on the reference sensor.
used Clark's garage process to bypass alarm.
looked over every thing.
pull dist cap to verify rotor button good. new rotor, dist, wires, coil.
verify 12v to coil
verify cam turns.
when I put a test plug on a wire and ground, never see any spark.
when cranking I can smell some gas. had tried spraying some gas in the AFM but not a burp.
out of ideas to check. will be reading through the 'no start' threads some more but will appreciate any ideas. I will not flame you for simple suggestions.
this is my first 951 build, but had done work on 944 before. but definitely no 944/951 expert. but learning way more than I had expected.
seems everything I check/test looks good.
for reference and since we all like pictures.
what I got. and when I took out for the drive.
http://forums.pelicanparts.com/uploa...1404245094.jpg
http://forums.pelicanparts.com/uploa...1404245124.jpg
TrailRider 07-01-2014 02:51 PM
Sorry you are going through this after your refresh... Nice car.
Do you have "slight" tach bounce when cranking? Like a 16th of an inch.
Timing belt okay?
I've seen some individuals have issues with the ignition / starter wiring which caused a no start condition.
911tracker85 07-02-2014 05:41 AM
tac inop, so no bounce. that is why I borrowed an O scope. speed sensor generates nice saw tooth and reference TDC hits. verified both at the DME plug.
any idea how to confirm if a starter switch?
TrailRider 07-02-2014 08:44 AM
Here is a no-start thread that sounds similar to your scenario that was fixed by replacing the ignition switch -
http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/792104-no-start-im-stumped-2.html
911tracker85 07-02-2014 09:44 AM
considered a possibility. but when key turned on, all dash lights, PW, etc all seem to work.
thanks, but now need to find how to test.
TrailRider 07-02-2014 08:31 PM
Agree... if you find out post it up.
It seems the poster in the other thread ruled out just about everything else...
911tracker85 07-05-2014 06:15 AM
ITS ALIVE
bad coil. probably should have commented that I had only verified 12V to both coil leads.
could not find my test light last weekend. found it yesterday and verified the NEW coil was bad.
going for a nice, long drive this morning. hoping I make it home. LOL
check to be sure I have my AAA card with me.
TrailRider 07-05-2014 09:45 AM
Nice! Thanks for reporting back. Enjoy the drive!!
guru944 07-08-2014 01:27 AM
Recommend MSD Blaster 2 coil upgrade...increase spark by 30%.
Later...
911tracker85 07-08-2014 03:12 AM
that is what I had bought. was told this is the first such failure they know.
