garage sale
Clearing out my garage, help me make some room. Feel free to make me an offer on any item.
Stock intercooler, good condition and no dings-- 100 Stock hard pipes, small dings -- 40 working ISV-- 40 86 951 DME, known working, with APE stage 2 chips-- 260 86 951 KLR, known working, with APE stage 2 chips--260 Early N/A alternator--- 35 Pair of stock N/A front springs -- 20 2 pairs of stock spring top hats--10 each New set of late offset power inner tie rods, never installed and still in plastic --60 New set of late offset power inner tie rods, installed and used for about 1 week on the street before I decided I wanted to convert to early offset --45 Rebuilt N/A clutch fork with new bearing-- 100 set of factory 86 turbo M474 koni adjustable rear shocks, usable but probably need a rebuild--30 Set of factory 86 turbo M474 koni adjustable struts, one is good, one needs a rebuild, or turn these into double adjustables-- 100 Working 86 951 AFM-- 100 Used 2.5 bar FPR--15 factory 951 fuel pressure damper--25 working ignition coil--30 3" Adapter for cone filter for AFM-- 20 Used but working cycling valve--35 headlight motor--40 headlight bar with linkages--25 Complete pair of rear seat belts--100 Cam tower with early N/A cam-- 125 Bosch ignition control module off a 944S--20 4 late car cooling fan relays, 70 ea Used A/C drier--35 Brand new front cam cover with new gasket, never installed--50 2 pairs of used parking brake shoes and springs---20 each 4 fuse tester relays---10 each 3 Distributor caps--15 each 2 distributor rotors--10 each 3 OEM spark plug wire sets-- 30 each Crank/alternator pulley--25 2 power steering tensioners-- 15 each power steering pump-- 50 Also have all the power steering lines and tank, let me know what you need! edit: updated 8/14 Last edited by dougs951s; 08-14-2014 at 11:59 AM.. |
I am in for the headlight motor. I am also interested in ac parts.
Tom 1987 911 Targa 1987 944 Turbo 1976 911S 1973 Mustang Mach 1 351C |
A/C lines are sold. Headlight motor is available, as well as the A/C drier. Shoot me a pm with what you want.
updated--if its still listed I still have it.
