Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Close ICV for Boost Test?
I have maximum 3 PSI of boost, so looking for leaks. Sounded like something under the intake, so I checked the ICV.
When connected to the outflow of the ICV, with inflow open, I can't pull a vacuum. When I pressurize the outflow, I get noticeable airflow out the 'inflow'.
Is this normal under pressure - should this valve be airtight? I've heard people talk about it leaking out the connector and from the o-ring under the metal housing, but not about through flow.
2002 C4S 105kmiles
Boston MA
Old 10-04-2014, 07:29 AM
winter-hater club member
nynor's Avatar
you need to do the LED test to see if the KLR is throwing a code.
Porsche 951 RacerX - The Legend Returns...
i have one and i just leave it in situ.
"COOL PRIUS!" - Nobody Ever
Old 10-04-2014, 03:45 PM
I built the LED, it worked for a no-TPS test, but was often giving small intermittent garbage otherwise. Most of the time it reads nothing. I just put up a larger test thread here.
2002 C4S 105kmiles
Boston MA
Old 10-05-2014, 10:21 AM
