Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
txhokie4life's Avatar
951 Track/Racing Iron Sleeved Short Block ForSale
If you are looking for a rebuild for your next race/track season -- I've already bit the bullet and have one built waiting for a new home.
Long story short -- I did a block rebuild due to a spun bearing (at idle) and
an oiling issue. After the rebuild -- I still had the oiling issue --
jumped through many hoops testing everything. Then swapped blocks,
still had the problem == which means this short block is totally fine.
Found the problem in the cam tower.... good size nick in the cam journal.
We swapped the cam tower and car runs great with solid OP.
Since I'm planning on selling the car -- no interest in swapping the
track motor back in.
$2500 firm (I've got way more into it than that).
Maybe 50 street miles on the block -- (Low break in RPM driving, I drove it home, didn't like the oil numbers (1.5 - 2bar) -- brought it right back to the shop the next day and swapped the short block).
86 Turbo 2.5L Block
Iron sleeves, decked.
LR custom fit rings
All new bearings, main and Rod
Arp Rod bolts
Windage ports milled between 1-2. & 3-4
LR cross drilled crank
Rebuilt oil pump
New pick up tube, tube reinforced, custom support
Aluminum welded baffle
IJA crank scraper
Welded Pick up ring
Balance shaft deletes and return holes welded
Tapped for npt turbo oil supply feed.
Upgraded one piece OPRV
rebuilt oil cooler assembly.
I think that's everything....
I can certainly take pix if needed.
If your local to Austin area -- I can even have the block installed for a reasonable cost adder.
Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 12-09-2014, 10:06 AM
Oil Pan with baffle was removed for inspection, but is included.
2001 996 GT2
Old 12-10-2014, 01:42 PM
Super Moderator
nize's Avatar
just curious, what does the engine number on the block say? m44/xx ?
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 12-29-2014, 02:59 PM
Sold
Old 02-11-2015, 09:26 PM
