Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
alpom's Avatar
transmission oil cooler modification
hello,
i have leaking problems with my transmission oil cooler. its leaking from the right side of the transmission where it hookup. i just changed the seal and its still leaking... too much to drive it. The metal from the cooler part seem damaged... do i need to change the cooler or is it possible to only change the "coupler" that goes into the trany. is there a way i can modify this part so it doesnt leak anymore? like a banjo bolt or something like that.
thanks for the answers guys.
alex
Alfa Romeo Spyder veloce restored for SALE
Porsche Black 951 restored (engine, trany, body, etc) SOLD
Porsche Black 911 1993 race car cage not finish 3.6 (SOLD)
Porsche grey 911 1970 E (SOLD in pieces)
Old 04-21-2013, 01:30 PM
Super Moderator
nize's Avatar
it looks like it's just a push-fit with a bracket, so you can replace the o-ring.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 04-25-2013, 04:03 PM
alpom's Avatar
o ring is brand new
Old 05-02-2013, 05:40 AM
Super Moderator
nize's Avatar
maybe you need a bigger o-ring?
Old 05-03-2013, 05:50 PM
kens_74_911s's Avatar
Cooler Fittings
Originally Posted by alpom View Post
hello,
alex
I had a request to make some hose fitting adapters and need the dimensions off stock fitting ends
A=Diameter
B=Diameter of retaining groove
C=Width of retaining groove
D=Dimension for outside of retaining groove to end of Dia. A
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3
81 VW Caddy Pickup X2 now...
84,85x2 .86,87,944. 82-924,88-924s parted with inventory!
68, 70, 72, 73, 911~ 70,73 914 past P/cars
Old 02-08-2015, 08:29 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
Same issue on mine. One fitting was damaged and O rings wouldn't help. fortunately one Rennlister had one he was just going to toss, so He's sending it to me. PO had tried with silicone seal to staunch the leak but it was a bust. It'll be good to get the cooler, so I can mark this issue of my list of things still needed to complete before the cars road worthy again. Porsche want's nearly $900 for these things. Not surprising since they want $42 for a $3.50 wheel bearing inner seal.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 03-05-2015, 12:30 PM
Dims
Still looking for the dimensions posted below to make some custom fittings.
K
Old 03-05-2015, 01:06 PM
JUst a thought re tap re thread and americanize it then the fittings are much easier to get if u can. just a suggestion. u can go bigger not smaller. but u can also create a nightmare
Old 03-12-2015, 07:57 PM
fittings
The fitting into the trans is an internal o-ring seal. The stock tube fitting presses into the ID of the casting sealing on the o ring then the U shaped flange keeps it from blowing out. A similar concept is used on AC fittings.
This relates to why I am looking for the dimensions to make some adapters. I don't have a turbo trans or a 951 but do have cad skills and machining capabilities... I'll buy someones old fittings that slip into trans if nobody has calipers to measure or time to get these dimensions.
LMK
porscheken@nc.rr.com
K
Old 03-12-2015, 08:51 PM
