Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
83' 944 wont start with new relay
Hi ya'll,
I recently picked up a 1983 944 and im loving it! The only things im not loving so much are the electrical issues.
Originally I thought the car just had a bad relay as it would turn but not fire. I went and bought a brand new relay but that didnt seem to fix the problem; the car turns but does not start.
The fuel pump has also been replaced with an OEM Bosch pump and new OEM spark plugs. I also have pressure in my fuel rail if that helps. My speedometer does not work and neither does my fuel gauge.
I went to Clark's garage and followed his repair procedures;
1. Checked the position and speed ref sensors - they appear to be working
2. Tested the relay - its working
I tried to short pin 87, 87b, 30 and the car started up. I drove it around and it seems to have no other major issues.
To recap, my car works when i manually short out pin 87,87b,30 but does not start when I put in a brand new relay.
anyone have any ideas?
Old 06-01-2015, 05:21 PM
Looks like i accidentally posted this in the turbo forum. Can an admin move my thread over to the NA thread. Thanks.
Old 06-02-2015, 07:33 AM
The newest of the noobs!
grendiers's Avatar
Sounds like the ignition switch malfunctioned. Easy to replace and cheap.
1989 944 Turbo
2004 Jeep Wrangler Unlimited - Built!
1985 Saurer 6dm overland Swiss military truck/camper
Old 06-02-2015, 10:13 AM
But my car works when i turn over the key. are you saying the wiring from the ignition switch to the fuse box is bad? How would i go about fixing it?
Old 06-02-2015, 10:20 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
It's not unusual to get a bad relay. I suggest buying a couple more (one for now and a backup). Buy them from PP because they're the latest version.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 06-02-2015, 10:37 AM
Quite unlikely, considering the OP description of the symptom. Either a bad DME relay or a bad DME ECU.
Good luck, George Beuselinck
Old 06-02-2015, 12:15 PM
if thats the case, then my new relay must be defective? Is there anything else that can cause this problem?
Old 06-02-2015, 02:30 PM
