Exhaust Manifold studs vs bolts
I finally couldn't take the rattles and removed the exhaust manifold off my 951 and ripped off the 2 remaining heat-shields. I sent it off to Jet-Hot and should get it back this next week. I'm replacing all of the gaskets and hardware as well, but I'm not sure why I would put the studs back in. Any drawbacks to using some high quality bolts?
-Matt '93 Rx-7 '87 951 |
With a stud, you are supposed to use a locking nut so it won't loosen. You can't do this with a bolt.
If a bolt loosens, then all the load goes to another bolt. Several years ago I lost a locking nut on my 1-4 header. The remaining stud broke off at #4 right at firewall. It took me two weekends to cut the stud out of the head. I also had to limp home from Road Atlanta with a big exhaust leak near the fuel lines in hot weather. The old header did not have an expansion joint so there was a larger load on the studs. But if one loosens, the load on its partner has to go up. |
Another reason for studs is that you can apply torque more accurately. And, furthermore, you don't wear out threads in aluminum engines in something that has to be removed occasionally.
It seems to me that the stretch or deformation of the threads for same torque is less with a sud since you have 2 sets of threads.
drew1 |
