-   Porsche 944 Turbo and Turbo S (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/)
-   -   Help! My fqs switch snapped off while trying to adjust. (http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/883052-help-my-fqs-switch-snapped-off-while-trying-adjust.html)
speedfrk 09-14-2015 02:57 PM
Ok so here is what happened. I used the tutorial for adjusting the dme fqs switch in order to try and remove some fuel enrichment from the stock table. I used the 2.5 mm Allen wrench and the potentiometer switch snapped off. I couldn't get it to turn and now have no idea what setting it is on. I can now turn the pot switch but because the stop is gone it can just spin and spin. I am not really sure what to do here...I want to set it to position 2 for the -3% fuel enrichment with no timing retard. Is there any way to identify which position the pot is in without the stop?
soxnail 09-14-2015 05:34 PM
It is actually not a pot but a switch.
If you broke off the stop point you should still be able to feel the switch change settings, it will be a soft click definitely felt.
IIRC there is a bigger gap in the "clicks" when it goes from 7 to 0 all the rest should be shorter so you could figure out where 0 is and set to 2 more clicks from there.
Do not keep spinning it around as you will wear out the stop hitch that produces a click. Then your choice will be to open the DME and use a meter to set it or replace the switch.
Sox
speedfrk 09-14-2015 08:21 PM
Thanks for the advice. I'll give it a try tomorrow.
mytrplseven 09-15-2015 06:36 AM
Scary stuff....
