manual boost control
which way do i turn to lower boost? it is a little blue manual boost controller. it is made of aluminum and a simple knob with a threaded locking jam "nut". i am pushing 18-20psi and want to turn it down to 12-15psi. my camera is dead. until i post some pics, any ideas...?
1988 944 turbo |
i am charging camera as we speak !
1988 944 turbo |
ok, here we go. btw, it has a stock wastegate.
1988 944 turbo |
it has been "forever" since i installed it. i want to adjust it the right way, so as to avoid overboost.
thanks, rick
1988 944 turbo |
I would guess you would turn the knob counter-clockwise to provide lower boost (open valve more). assuming of course you have a stock single port wastegate.
1986 951 |
Give it a half turn one way and see if you get more or less boost .. If it goes more you are not going to hurt anything if you over boost for a couple of seconds.. I have a manual boost controller and I have to turn it the oppisite way it says to adjust it. At first I though I was lowering the boost but I was raising it. Once I say the boost go up more I let off the gas and turn the knob the other way and it went down...
Thanks guys. Yup, counter clockwise lowers boost.
1988 944 turbo |
What kind of boost controller is this? I have the same one on my car from the previous owner and I am trying to figure out who it is made by.
Thanks Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52 |
Get rid of it. It was susceptible to small changes in temperature. And gave inconsistent boost ranges.
Accuboost-1 controller. One of the better manual controllers out there, but has limitations of mechanical devices.
- Inconsistent boost from day-to-day when the temp and humidity changes. - higher boost in higher gears - dropping boost curve in upper RPMs Last edited by DannoXYZ; 10-22-2015 at 03:04 AM.. |
