Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 944 Turbo and Turbo S
Question 1991 944 S2 Initial Maintenance
Thanks to everyone who help me get the car home!
I had a chance to meet up with a local PCA member and he was kind enough to help me put the 944 on his lift and help me do some preliminary inspections.
I'm attaching the pictures I was able to take and here are initial observations:
Link to pics:
https://drive.google.com/open?id=0B2cGvNDtmfJULTNMSHg2T3lCLWs
-Suspension looks original, some bushings definitely need to be replaced along with shocks / struts
Also the rear end of the car sits low I think that should be raised with new suspension?
-Wasn't able to figure out the speedo issue
-Looks like a power steering fluid leak but not dripping under car
-Belts look to be in good shape, water pump is new as is timing belt
-Rear brakes are getting low
Any other thoughts those with lots more knowledge can provide would be greatly appreciated!!
Old 03-20-2017, 02:46 PM
In the Fires of Hell.....
kdjones2000's Avatar
You are in the Turbo and Turbo S specific forum here, so not the best place to be posting about your S2.
One thing I would suggest is to check your cam tensioner pads inside your head. If the pads wear too much and are not replaced, you will break the tensioner and crack your head.
'88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG
3120 lbs, 256 RWHP, 15 psig boost
NASA/PCA Instructor
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - WIP
Old 03-22-2017, 07:18 AM
Ah sorry - I'll repost to the correct thread. Thanks!
Old 03-22-2017, 12:44 PM
Tags
944
