Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Going faster all the time
Litesonic's Avatar
Non-start issue
After sitting for an extended period of time... 18 months... I have finally completed all of the maintenance items that I could tackle this time around.
This included the timing and balance belts as well as a water pump, new rollers, distributor cap, rotor, new plugs and wires.
I have also replaced the engine bay fuel lines (all three elements), had the injectors serviced, installed a new oil and air filter, cleaned the intake manifold, replaced the AOS and it's seals, rerouted the hoses back to a more stock configuration, though still with the venturi delete.
I have also replaced the coolant and the hoses.
So after fully charging the battery, I began the process of waking her back up, with the anticipation of checking for leaks, and bleeding the cooling system.
She cranked, and seemed like she wanted to fire, but stumbled and coughed out. Never making even a lumpy idle last.
I drained all of the suspect fuel via siphon (though I had added stabil one month into her rehab), and replaced with fresh gas. Same result.
I know it's very difficult to diagnose remotely... but am I missing something?
All of the wires are plugged in, All of the injectors appear seated, there are no fuel leaks. The most (including under the manifold) vacuum lines have been converted to silicon, I have replaced any other cracked hoses.
The car ran before I began disassembly... even passing smog. All of the gauges appear to be working... I have oil pressure, and volts.
Now: 2006 Cayenne Turbo S Titanium Gray | 1986 944T Black
Then: 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory
Old 10-06-2017, 08:28 PM
In the Fires of Hell.....
kdjones2000's Avatar
Have you switched the connections on your Speed/Reference sensors and tried?
After that, look for the Holy Trinity: Fuel, Spark and Timing
NASA/PCA Instructor
'88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
Old 10-07-2017, 05:14 AM
Litesonic's Avatar
Thanks Mr. Jones,
I didn't touch those, so I am leaving those sensors out of the equation.
I will attempt the fuel pump jumper first.
I did rotate the engine by hand after this and made sure that the marks line up... so far so good.
I don't want to keep cranking an engine that won't fire, but I want to make sure I tried enough to pull the new gas in. I am thinking making sure the pump hasn't perished (or the relays) would be a good step to start with.
Thanks again
Old 10-07-2017, 07:43 AM
JackkTheMackk's Avatar
Are your plug wires all orientated correctly?
Check your fuel pressure also.
1982 911 SC Targa - Guards Red
1986 944 Turbo - Zermatt Silver
ZeroFuchsGiven.com
#ZeroFuchsGiven
Old 10-07-2017, 08:32 AM
Litesonic's Avatar
Thanks Jack as well,
They are (neatly labeled and solidly clicked into place).
I think the issue will be with the timing, I have a new woodruff key on the way.
I'll update as I trouble shoot.
Old 10-08-2017, 05:34 PM
acar24's Avatar
The fuel injectors are bad about sticking might have to take out and flush them with a cleaner.
good luck . la
Old 11-02-2017, 10:01 PM
