Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 944 Turbo and Turbo S
MAF from dmeshop24 wiring install
Checked their website and it shows a picture then quickly switches the page to something else?!
The 4 pin stock connector to the AFM has a plug that adapts to the MAF, but
I still have a loose red wire and a black wire.
Where do these go?
Red wire to 12V key on for the MAF power?
PCA since 1985
77 924 MARTINI Edition rescued,SOLD
88 924S Special Edition rescued,SOLD
Comeau Racing Enterprises, Inc. www.comeauracing.com
We do only 924S, 944's, 968's all day, every day.
Old 11-20-2017, 12:18 PM
In the Fires of Hell.....
kdjones2000's Avatar
Tim, I looked at their site and only found a MAF for the 944 Turbo. No details about how to wire it up, either.
'88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG
3120 lbs, 256 RWHP, 15 psig boost
NASA/PCA Instructor
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - WIP
Old 11-22-2017, 04:35 AM
Thanks for the reply, my 944 Spec brother....
Yeah, seems that redirecting of the page is to get you to pay or register?
PCA since 1985
Old 11-22-2017, 06:40 AM
Pulling my hair out......
Been all over the web. Can't find where to plug these two wires for this German "DmeShop24" MAF kit. Confusing part is that the two wires are split from the same wire and ohm out as a short. ( they are connected). German website has no install instructions. Translated the whole@#$%^ website.
I've looked at Lindsey racing, Vitesse, Miller websites for clues.
Their length and the fact that they have bullet connectors, 1 male (red), 1 female black), suggest that they might be using the diagnostic plug next to the brake booster for power.
The rest of the wires are accounted for as they are a direct plug in to the factory AFM connector.
PCA since 1985
Old 11-25-2017, 12:23 PM
Here's a pic from the Vitesse install.
https://rennlist.com/forums/attachments/944-turbo-and-turbo-s-forum/358740d1242364043-vitesse-maf-installation-completed-you-can-do-it-too-pic-6a.jpg
PCA since 1985
Old 11-25-2017, 12:38 PM
if it does in fact go to the diagnostic plug, i wonder if they short out to bypass the idle valve for some reason related to that MAF setup.
on my old Rogue MAF it just had a single red wire that ran to the coil+ terminal for power.
Old 11-26-2017, 06:46 AM
