Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 944 Turbo and Turbo S
Rear Hatch Squeak
Title says it all. I have done a fairly complete search of the technical forums and have not found an answer.
I determined that the latch pin holder impinges upon the body and that by inserting a piece of tool box drawer liner, the squeak is eliminated. Is there a way to adjust the position of the entire rear hatch forward to clear the interference?
I am looking for a long term fix.
Hatch wear pattern:
Where hatch pin holder impinges on body work:
A bit of <Lowes> tool box liner inserted eliminating sqyeak:
TIA,
Peter
Old 02-21-2018, 10:51 AM
In the Fires of Hell.....
kdjones2000's Avatar
Sounds like your hatch may be separating, causing this. Look up near the hinges and see what's going on.
To answer your question, yes the hatch can be repositioned via the hinges, but you will have to take some of your headliner apart to get to it.
'88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG
3300 lbs, 256 RWHP, 15 psig boost
"Certified National PCA Instructor" Hoooohah!
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
Old 02-21-2018, 12:45 PM
I have the same problem, and I think I will try a few layers of rubber insulating tape to stop the squeak.
Old 02-22-2018, 02:01 PM
Got the same thing going on...I am going to give the padding a try too.
Collection Manager for HH Motorcars, LLC
hhmotorcars.com
Old 03-31-2018, 06:24 PM
