Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Ignition Timing Not Advancing
Does anyone know what controls ignition timing, from beginning to end? I'm guessing that it starts with the TPS, which signals the DME or KLR. I have also read that the knock sensor will effect timing advance. My mechanic says the ignition timing is not advancing. It seems to me that it should be a fairly small flow chart to determine what could be the problem(s), so a concise test plan can be developed. I doubt it's simple, but any ideas would be appreciated.
Old 03-06-2018, 01:55 PM
In the Fires of Hell.....
kdjones2000's Avatar
Look at the "DME Test Plan" for direction on this.
I would also get a new mechanic...
NASA/PCA Instructor
'88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
Old 03-06-2018, 05:20 PM
Main selector of ignition is AFM X RPM which determines which data-cell on 3D map is selected. RPM is determined by flywheel speed & reference sensors. TPS WOT switches to full-throttle 2D map. Think of that as the highest-load row on 3D map's "wall". Below WOT, TPS doesn't affect ignition at all. Here's fuel & ignition maps off a 951 (R.O.W map I think). Actual fuel & ignition values used is selected off X-Y coordinates off LOAD(AFM) X RPM scales.
Mechanic is probably old-style and thinks rotating distributor affects ignition timing (it doesn't). Find another more modern mechanic that knows how to use oscilloscope and computers for diagnostics.
Old 03-10-2018, 04:09 PM
soxnail's Avatar
Knock sensor input will retard timing about 3 Deg instantly. The ECU will then advance it again slowly. Give it (knock sensor) a tap with a socket extension adapter or something similar. NOT HARD !
If you have access to an oscilloscope hook it up to the output from the KLR to the DME pin 32 iirc
and you should see it. Or else a strobe on the ignition wire should show it too.
Sox
"Little problems always come back and bring bigger friends with them".
1986 951"MADDOG" black with maroon interior
All stock with shimmed WG
Old 04-02-2018, 04:45 PM
