Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
electrical connections
I the AOS on my turbo and methodically marked and zip parts all small parts with location. I must finally be growing up(I took the time to do it).
Small problem. I did not mark which connector went to which connection on the two connectors at the firewall. Here is a picture. They clip into either connection being twins. A way to tell which one goes where?
Thanks,
Ed
Old 06-29-2018, 06:30 PM
In the Fires of Hell.....
kdjones2000's Avatar
Put them in one way, if the car starts, you chose well.
If not, swap and try again.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 06-29-2018, 10:59 PM
Thanks,
I wanted to make sure that I didn't plug in backwards and find out by doing that I cooked something else.
Thanks again,
Ed
Old 06-30-2018, 11:21 AM
