-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Speedometer + Spoiler + OBC inoperable (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1000220-speedometer-spoiler-obc-inoperable.html)
hexagone 06-21-2018 02:20 PM
Have been trying to diagnose a fault:
My speedometer does not work, and as a result the spoiler light is on, and the OBC does not read speed either. '97 Tiptronic 993.
* ABS works. All Speed sensors ohm at ~1700. No ABS light.
* Driving the car, the ABS engages fine.
* Speedo still not working, spoiler light turned on. Can't imagine the ABS ECU is at fault either because ABS works and no light is on.
*The OBC does not receive a speed signal either. What does that indicate?
The problem is also identical to the one below, but none of his fixes (short of replacing the ABS ECU) have helped:
http://forums.pelicanparts.com/porsche-964-993-technical-forum/401074-speedometer-obc-spoiler-weird-problem.html
