-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Lowering Engine temperature (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1000989-lowering-engine-temperature.html)
Rickness 06-29-2018 05:51 PM
I'm looking for input. I know with water cooled engines, sometimes removing the thermostat,or reducing the thermostat operating temp lowers overall engine temperature. (No heat in winter) I want to do that with my 993. Does anyone have any experience with that. I have tried to buy lower temp thermostats, but they don't make them, according to everyone. I have purchased for my Jeep lower thermostats. Heat kills. I did it with an Opel , and feel strongly that the extra 100,000 miles I got on the car directly related to the lower engine temps, and still got 30 mpg.
LouZ 06-30-2018 05:33 PM
You DO realize that it's air cooled!!?? There is no thermostat.
The best way to lower the engine temp is to remove the undertray.
Kein_Ersatz 06-30-2018 08:12 PM
There is a temp control valve for oil circulation to the front radiator as part of the oil tank.
Oil/coolant temp is not engine temp, but fluid temp. Oil is designed to run at a temp range. If you succeed in lowering temp, then oil lubrication may be effected.
Drop trays and air cooling is improved.
Newsboy 07-01-2018 02:53 AM
There is a thermostat, but it's for oil temperature, signals when to send oil to the front oil cooler.
Bill Verburg 07-01-2018 06:13 AM
There are actually 2 t-stats
1 for the oil is located in the oil filter console beneath the oil tank, #16 and the other is for the fan in the right front wheel well that moves air through the cooler.
http://forums.pelicanparts.com/uploa...1530450464.jpg
The t-stat operating temp is determined by a phase change of a wax like material, I'd need to look it up but it's ~180F. There are no options here.
Stock the oil coolers work fine for most street use. If the temps get uncomfortably high
http://forums.pelicanparts.com/uploa...1530450752.jpg
say ~248F, you add another oil cooler in the left front wheel well.
targa72e 07-13-2018 12:49 PM
you can get a lower temp fan switch to turn the cooling fans on earlier (or jumper ir to run when the car is on). You want the oil temperature above a certain temperature before sending it to the front cooler or you risk blowing out the oil cooler with too much pressure from thick oil.
thanks,
john
