Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 964 & 993 Technical Forum
993 oil won't drain from fill tube.
Hello everyone, so the problem is that when I add a bit of oil to her ( very little) the oil fills the neck of the fill tube and just sits there. Engine running, reved, and the engine is not over full checked by the gauge and dipstick. It's only when I take her for a short drive that it finally sucks down the oil. This has happened the last two times I've checked and added oil to her. Never has happened in the past, still has the factory fill tube extender fill neck thing which has an intact grate on the bottom preventing debris from entering, so there should be no obstructions... Looking if anyone else has experienced this or knows what's going on. Thanks in advance! I'll post a pic of it as well.
Old 07-01-2018, 04:44 PM
Bill Verburg's Avatar
Just raise the rear of the car a few inches, here's what I do for oil changes
Bill Verburg
Old 07-02-2018, 06:07 AM
Thanks Bill, I just figured gravity would already take the oil down even on level ground.
Old 07-02-2018, 08:51 AM
