Clutch Lever Ball Cup Bushing
Trying to replace the “angular joint” in the shift rod mechanism as the ball cup bushing has failed. I have everything apart and the new part but cannot get the jam nut loose. What is the best method of getting to angular joint off? Is there some secret to this?
Maybe a picture of what joint you are describing will help , could swear I responded to this inquiry
once before, thanks Bert
GT2 RS 3.2 RSCS 3.8 R 2.5 Twin Plug |
