65rsr's Avatar
Replacing 993 plastic oil fill line
What is the trick to install the oil fill line that goes from the oil fill tube to the oil tank? (a 4 foot black plastic hose that looks like it's from a shop vac) Fishing the hose through the chassis is the problem, especially getting it past /around the shock tower is the hard part. The old hose has already removed. Any ideas?
Old 09-10-2018, 05:49 AM
budge96's Avatar
I believe I've seen it done with a fishing wire like coat hanger attached on the front end, it may even be easier to bring it back the other way.
GT2
RS 3.6
RSCS 3.8
R 2.5 Twin Plug
Old 09-10-2018, 12:46 PM
KNS KNS is offline
This has been a weak spot on a few 993s, Iím dreading this replacement when the time comes.
There was a fellow on Rennlist that did this about a year or so go. You might try searching over there.
Kurt
1984 911 Carrera
Old 09-11-2018, 06:09 PM
This is more of a pita job than I thought it was going to be when I replaced mine. Some wire and a lot of patience.
Old 09-13-2018, 06:47 AM
