cmw cmw is offline
993 Billet Engine Cases
Our New 993 Porsche Billet Engine Case getting closer Getting all the proofing done. Along with our new 5.0L Billet Engines coming Soon. Those engines will be available through Redstone Performance Engineering, Contact Garnet @ 317-445-6313 or email redstonePE@gmail.com
Scott Cousimano
Nitro Mafia Racing
6845 Speedway Blvd. Suite K105 Las Vegas, Nevada 89115 (562) 544-6947
www.cmwmotorsports.com
Old 09-11-2018, 12:31 PM
5.0L for a 993 Air-cooled platform?
Old 09-12-2018, 10:36 AM
clutch-monkey's Avatar
is that meant to be 4.0L?
Old 09-13-2018, 02:17 AM
hum...... sub'd
81 SC 3.6 conversion
06 Cayman S
16 4Runner trd pro
2012 Lexus IS-F
Old 09-13-2018, 01:12 PM
cmw cmw is offline
Yes, our 5.0 liter to start will be for the air-cooled platform. But we are making billet cases for both the 993 & Our 5.0 Liter Platform
Scott Cousimano
Nitro Mafia Racing
Old 09-14-2018, 01:28 PM
cmw cmw is offline
I am not sure what your meaning, the 993 billet case goes from stock to 4.2l, the 5.0 liter engine is completely different, looks the same from the outside, they will be set up for upside down fans, billet throttle bodies or slide valves for normally aspirated and turbocharged
Scott Cousimano
Nitro Mafia Racing
Old 09-14-2018, 01:31 PM
MMMM 993 with a 302, I get my Porsche and fox body fix.
Old 09-28-2018, 07:51 AM
Is there another thread on this forum, with a different company also producing billet cases for aircooled 911s?
Old 09-28-2018, 11:58 PM
Ora Ora is offline
Banned
Yes, the people are Home, they got one nifty case in the works.
Samuel.
Old 10-01-2018, 03:26 PM
gearhead
Samuel.
That's not billet. That's an all new casting.
1974 911 Restorod
1974 914 Bumble Bee
1975 911S Tom's Targa
2008 Cayman S Mule
Old 10-02-2018, 05:38 AM
Chain fence eating turbo
You should post this in the 911 forum too.
People will be chomping at the bit to put a huge motor into an early model!
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 10-02-2018, 07:49 AM
Ora Ora is offline
Banned
Yes indeed not billet, it is heat pressurized to 30K pounds at 900F,and the finish on the case looks fantastic indeed.
Old 10-02-2018, 01:03 PM
Cobalt's Avatar
A quality sand casting should not need the HIP process. HIP was designed to remove trapped gasses in poorly cast aluminum. A356.0T6 is a sand cast alloy. To be MIL spec it needs to comply with ASTM-B-26 or similar and all the requirements otherwise it is an alloy used but isn't MIL spec. HIP will not make a cast part stronger than a cast part that was devoid of gasses to begin with. If gases are present then something is wrong with either the melting process or sand mix. It is actually a cheap fix for lack of QC. Although doesn't hurt.
I would be more interested if they were radiographically or Fluorescent dye penetrant inspected to Class A Grade A or some established criteria to meet MIL spec and if they are certifying these to A356.0T6 or just using A356 heat treating it to T6 which anyone can do. Assuming they meet min criteria of separately cast test bars 24k PSI Yield 34K Ultimate Tensile and 3.5% elongation it should yield a stronger casting than the factory. Although I would expect integrally cast test bars and random sampling of a casting with sub sized bars would be better IMO.
In order to comply with the MIL specs sub sized bars from the casting only need to meet 75% of the requirements of the spec. I regularly saw 32k Yield 42k Tensile and 5% elongation out of sub-sized test bars cut from my castings when properly cast and heat treated. Although that was dependent on the house performing the heat treatment process which is rather complex to do correctly and even many DOD and NADCAP approved houses I knew of cut corners.
I am also curious how they plan to increase displacement? Will it use wider barrels or do they intend to increase the stroke which will require new jugs and heads?
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, '93 964 C2, '93 928 GTS 5 speed, '94 Turbo 3.6, M '15 Boxster GTS18 Macan GTS
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS many others
Old 10-11-2018, 06:03 AM
