Help! Hard knock after RS clutch/flywheel upgrade
Hello everyone!
I just fitted a RS clutch/flywheel kit to my MY94 993 Carrera 2 and when I run the car (idle) I notice a very hard knock around gearbox area.
If I press the clutch, the knock disappears.
The gearbox was also fully rebuilt but I don’t suspect the noise comes from it because we have successfully rebuilt some with any issues.
Does anyone ever experienced this and knows a possible cause?
I have already taken the gearbox from the car, disassembled the clutch mechanism, clutch and flywheel with any evident wear or trace on this parts that can lead me to a cause...
Thanks in advance for any help
993 Carrera 4 1995 artic silver, 993 Carrera 2 1996 Black
911 SC 1982 Linen Grey Metalic
RS clone Tarmac rally car (under construction)
911 T 1968 - waiting for better days
911 T 2.4 1972 SOLD
Old 11-29-2018, 09:56 AM
Mike Billings's Avatar
My '96 does the same thing.
It's caused by the RS clutch.
The dual mass flywheel you removed is a very heavy instrument that is designed to reduce the noise.
Hopefully you will come to enjoy the noise!
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R6 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 3+
Old 11-29-2018, 10:41 AM
911 jared
911 jared's Avatar
Send a message via AIM to 911 jared
Im pretty sure its “clutch chatter.”
Common issue when these cars run solid trans mounts or lightened/rs flywheel.
95' porsche 993 carrera 2
89' porsche 964 carrera 4
87' porsche 911 carrera (sold)
05' honda s2000 (sold)
Old 11-29-2018, 10:45 AM
Thanks for your messages.
So, I should assume this is normal and nothing bad will happen to the new components?
And yes, I also fitted hard mounts to transmission and engine.
Thanks again for the feedback.
911 T 2.4 1972 SOLD
Old 11-29-2018, 05:15 PM
JFP in PA's Avatar
Originally Posted by AlexJ View Post
Hello everyone!
Caused by the single mass flywheel; now you know one of the things a dual mass does for the car...…………...
Accrochez-vous bien de vos ręves..........."
Old 11-30-2018, 06:18 AM
Now I know! Thanks!
911 T 2.4 1972 SOLD
Old 11-30-2018, 07:52 AM
A good read, if you’re interested.
http://www.techtalk.ie/wp-content/uploads/2018/01/LuK_tec_brochure_dmf_de_11_2017.pdf
Old 11-30-2018, 02:34 PM
Red Line Service
Marc Bixen's Avatar
540964, Great read, great info. Thanks!
Marc Bixen
Red Line Service
West Los Angeles, Ca.
Old 12-03-2018, 06:04 PM
Now in 993 land ...
aigel's Avatar
Oh man - I wish you would have posted before taking things apart! Mine does this intermittently as well. It had the LWF from the PO and it didn’t change after a new clutch / trans rebuild either!
G
Old 12-07-2018, 09:06 PM
Interesting... is the loud knock noise, consistent? Any way to hear it in a video?
Why would the 964 with a single mass flywheel make a knocking sound, when earlier cars with a SMF didn't? (I am attempting to learn something here).
Old 12-08-2018, 01:32 PM
<--- keeping stock flywheel, but I don't race at all
Iron Hill Restorations
Specializing in vintage Porsches
Home of the 914 Umbrella Cover
'91 964 Targa guards red, cashmere
several 914's and loads of parts
Old 12-11-2018, 10:57 AM
Now in 993 land ...
aigel's Avatar
I would not describe it as a knock. Most the time it is a shattering sound. Sometimes it is a loud click - definitely not something like a rod knock or pinging.
I do not quite understand the mechanics behind it... (edited after reading the LuK article ...) I just recall searching or asking about it here when I bought the car and was freaked out.
G
81 SC (sold)
Old 12-11-2018, 11:06 AM
The article from LuK explains a lot
Old 12-11-2018, 11:08 AM
Ora Ora is offline
Banned
G
Marbles loose inside the tranny!!, normal.
Old 12-24-2018, 10:29 AM
Back in the uk I fixed this noise successfully .
I simply installed a cat by-pass straight into a fabspeed dual outlet rear .
Problem solved .
Old 12-30-2018, 09:26 PM
964TargaC2's Avatar
Problem solved .
I had that setup for a month before I baffled the outlets, it set off car alarms and rattled windows!
what condition my condition is in
Old 12-31-2018, 10:48 AM
Alps Adventurer
Traveller's Avatar
Send a message via Skype™ to Traveller
Hello everyone!
I just fitted a RS clutch/flywheel kit to my MY94 993 Carrera 2.
Just curious, but what made you go for it over the stock set-up? Was the original worn out and slipping?
Are you on the track most of the time?
Old 01-04-2019, 03:05 AM
Did you happen to also change the gearbox mount? Recently changed mine with the original Porsche Classic part 964.375.055.81 in a preventive "while the gearbox is out of the car" attempt. Following the reassembly I was under the impression something is broken or the drivetrain is in contact with the body. Upon further investigation we realised that the new Porsche part has been re-produced by Porsche with way too hard rubber insert (almost as hard as concrete) and had to source a used gearbox end plate with a used (but still good) mount still pressed in.
Old 01-06-2019, 03:45 AM
That is what I did! Changed the hard rubber mounting by the original one, and 80% of the noises disappeared!
911 T 2.4 1972 SOLD
Old 03-01-2019, 04:45 PM
Imcoz's Avatar
Curious why my 964USA Cups don't exhibit this rattling or knocking? I'm assuming the USA Cup has a SMF?
Coz
92 964 Cab
88 911(track-black)
93 911 RSA - bodied as a 993RSR
81 IMSA RS Capri
Old 03-15-2019, 09:45 AM
