G64 Transmission Rebuild Literature?
I've got the engine and trans out of the car for a clutch and it's turning into a larger and larger project as I find more things I'd like to address. My trans does leak a slight bit between the cases and I've got a full M/T seal kit on order. Is there any good reading material on rebuilding these? Things to look out for/inspect or replace and just general guidelines?
I've heard the planetary gear for the 964 C4 is particularly problematic and I've got a turbo thrown into the mix now. Anything I can do preemptively to keep this thing together? I've spotted a couple photos of people that have welded parts of the planetary gearset in place to keep those pegs from working their way out.
92 C4 if that helps any. Hopefully I'm not biting off more than I can chew here but the thought of all this work to have it out for the clutch and to put it back in leaky causes me agony. Thanks for any suggestions.
Old 02-19-2019, 09:53 AM
Tags
964 , c4 transmission , carrera 4 , g64
