-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Spark Plug Change (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1024949-spark-plug-change.html)
1990_C4_Cab 03-28-2019 09:02 AM
Spark Plug Change
I have a 1990 Porsche C4 Cab for which I'd like to change the spark plugs. There are only 6 plugs, correct? Can I perform the task from up top or do I have to go underneath the engine. Finally, do I need a special tool for this?
964TargaC2 03-28-2019 10:33 AM
there are 12 plugs, go at it from top and bottom
A magnetic spark plug socket helps although it can be done with the factory suplied tool
better google some videos, etc before you start
1990_C4_Cab 03-28-2019 08:55 PM
Thank you! I found all 12 spark plugs on the car and bought myself a magnetic spark plug socket!
Newsboy 03-29-2019 02:33 AM
You will need to remove things that are in the way, top and bottom. Top,blower motor, Bottom, cat and mufflers. Regular tools work. Cramped quarters on the top.
964TargaC2 03-30-2019 07:54 AM
do the ones at the back (on side where power steering pump is), #6, last as they are the hardest to do, you will have had ten other plugs to practice with!
1990_C4_Cab 04-01-2019 08:44 PM
You guys were spot on! Removed the items in the way and was able to get to the plugs. Much appreciated!
