993 standard lifters
Hi there
when you replace 993 valve lifters do you put oil in them before installation? I think i used to do that but it has been a while since i did this job... thanx for any re.. Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
While the lifter replacement procedure from Porsche doesn't mention soaking in oil, it's common practice with any hydraulic lifter/lash adjuster. If it's a situation where the car is already together and that step was skipped, I'd pull the DME relay and crank the engine over and get oil pressure flowing for a moment before it actually pops over and hits high/cold idle and makes a racket.
EDIT: I'll also add here that 20w-50 oil will take forever to prime the lifter, some regular 5w-30 is probably in order here just to not waste your life away waiting for the bubbles to all come out.
"Frankenstein" - 964 C4 chassis/driveline - 993 widebody/Speedster look - VEMS standalone - twin plug high compression 3.6L N/A engine - 945cc cc/min injectors - Bosch 044 pump - GT45 @ 1bar/14psi - non intercooled/wingless - E85 fuel - turbo inlet water meth inj. - 3.5" exhaust - GT3RS clutch + LWFW |
thanx .that is exactly what i did today;-)
Ivan
