964 Warning lights and intermittent surge
Hey, so I’ve had my 91 964 C2 for about a month. I got the “Christmas tree” effect with the lights and the warning horn. I changed the wires, distributor caps, plugs, coils, DME and unplugged and replugged the ECU. It seemed to have gone away, but now all my warning lights will come on but I don’t get the warning horn anymore.
I also get an intermittent surge in power while driving, like it wants to cut out(feels jerky). I replaced the fuel filter but that didn’t fix the problem. It idles fine and runs smooth other than the intermittent surge, I let off the throttle and it goes away.
Any recommendations or suggestions, it’s fun to work on these cars but can be frustrating when you think you have the problem fixed but returns.
Old 06-08-2019, 07:27 PM
Look at dry solder joints behind the instruments in the dash .
Old 06-08-2019, 09:16 PM
If you havent, check the earth strap betweeen the battery and the body and betweeen the gearbox and the body . The latter Will corrode w time and cause intermittent loss of contact.
Old 06-09-2019, 03:36 AM
964TargaC2's Avatar
If the cleaning of connections and clock soldering doesnt work I would get rid of the Bosch Silver coils, I had them fail within minutes of installation. They bench test ok but when they get warm they cause issues
Best option at present is switch to the 993 coils
what condition my condition is in
Old 06-09-2019, 05:18 AM
Thanks for the recommendations! I am going to check the grounds and the back of the instruments today. I just changed the coils a couple weeks ago, but maybe the 993 swap is the way to go. Does anyone know of a company that sales a plug and play kit? I know the wire ends are different between the 964 and 993.
Any suggestions on the surges in power while driving?
Old 06-09-2019, 07:53 AM
The grounding strap from my transmission to the body is missing. I just put one on order, can anyone explain the location on the trans and body that I need to bolt it to?
Old 06-09-2019, 12:21 PM
1. Starter fixing bolt on trans. 2 There should be a threaded hole in a groundplate at the base of the body om the rhs.
Old 06-10-2019, 04:27 AM
+1 Even if the ground cable (strap) looks okay, check its resistance on a low resistance scale on a multimeter. It should be virtually zero. Once when I was having issues with my 964, I measured 700 ohms on the main battery ground strap. A new cable fixed everything.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 06-10-2019, 03:36 PM
Swapping to 993 coils fixed the problem.
Old 06-25-2019, 04:34 AM
