-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Oil return tube issue (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1036714-oil-return-tube-issue.html)
jgilliam914 08-06-2019 12:53 PM
I bought this a few years ago and getting time to finally devote to it. When removing the HE I noticed the return tube was slightly crushed.
What is the best way to fix this and what is the easiest. I know one is usually not the same
http://forums.pelicanparts.com/uploa...1565121168.jpg
964TargaC2 08-06-2019 02:17 PM
Our host sells replacements that do not require removing the head, I bought the nice Aluminum Rausch & Speigel ones, a bit of silglide helps get them in
After you have the replacement remove your dented one with pliers, dont cut it off!
bazar01 08-07-2019 06:37 AM
If it's not totally crushed and does not leak on both ends, I will not bother replacing it.
Just drive and enjoy, nobody looks down there maybe except you.
