964
i have an early 89.- 964 3.6 engine all apart for a rebuild . ? on the heads iam going to use 102 p&c 11 to 1 compression ratio ,carillo rods ,the cyl have the head gasket ring in them .i think the the heads need to be fly cut out to allow the cyld;s to seal is that the correct way to do it , or not ?i think with my calculations the heads will be about 3 to 5 thousands lower . i am not going with bigger valves but will be using 993ss cams. wondering if any one else has gone this route ,and what problems i might encounter ? thanks .any input or info is appreciated . slammin
Today, 07:39 PM
Old 01-16-2020, 03:43 PM
Newsboy's Avatar
If it's 98, it would be a 993 engine.
Old 01-19-2020, 01:21 AM
Cobalt's Avatar
Agreed a 98 would be a 993 engine which is quite different. I would also never use slip fit 102mm Cylinders. If I were doing a 3.8 conversion it would be the big bore kit and pay for the machining.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 01-19-2020, 11:00 AM
An 89 perhaps?
Ralph W
Instagram @ ralphwlll
1990 C2 Cab
2006 Nissan Frontier
1986 F250
Old 01-19-2020, 02:25 PM
