89 964 seat belt
Need help/advice on how to get rear driver side panel off so I can change rodent eaten seat belt. I think I have all the fasteners out, 3 along top, coat hook and one in the door jamb holding vertical trim piece. Vertical trim piece seems to be holding things up, but can't find any other screws. Appreciate any advice.
Old 03-28-2020, 10:56 AM
Diving in 911
Rear interior qrtr
It slides in behind the door trim, which you likely know. The top trim has to come off, as thats what holds it on. There are three notches for it to fit around the spot welded trip mounts. There is a downward pointing hook on the interior panel that goes in first when you are putting it on. The panel has to be release from both the door and top trim panels, pulled away at the top and lifted out of the hard mount at the bottom the the hook on the panel slides into. You will likely have to remove the parcel shelf because it rides over the top on the side panel as well.
Hope this helps! good luck
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1989 964 Coupe/1992 964 Cab
1987 928s4 Granite Green / 1986 951
Old 03-28-2020, 02:01 PM
Thanks very much,
With all the time I have now, I'll get started today.
Thanks again, and keep safe.
Bob
Old 03-31-2020, 07:20 AM
Diving in 911
No problem!
Old 03-31-2020, 08:24 AM
