Heads up: 964/993 fuse box replacement
To All,
We just had to replace a complete fuse/relay panel on a 97 993. We want you all to know that we had two (2) bad brand new fuse/relay panels direct from Porsche. So, If you are unfortunate enough to have to replace one of these, and some components don't work after, don't feel bad calling the dealer and getting another. Replacement box 1: No fog lights No reverse kights No sunroof No brake booster pump (C4S) Box 2: No mirrors No HVAC (heat/air-conditioning) No windshield wipers Intermittent brake booster pump On box #2, if you pressed hard on the 60A unloader relay,R33, everything would work. Fuse panel #3, everything worked. And we don't get a labor reimbursement from Porsche, we have to eat it. |
| All times are GMT -8. The time now is 10:53 AM. |
