993 Odometer Broken
Hi all,
The odometer in my 993 has broken. Can anyone point me towards either good people to fix this or a way to fix it myself? Thanks, D. |
North Hollywood Speedometer if you're willing to send it to the USA. A common problem...odometer gears of this vintage prone to failure.
KYUKYU3
This is what to expect. If you are patient, careful, and halfway mechanical you can replace the broken gear. The teeth on the gear fail and eventually the odo stops turning. You can find the gear replacement parts from our host...
https://youtu.be/c4XOxU3EJ40 Sent from my Pixel 3 XL using Tapatalk |
There is a specialist in the UK who even Porsche use:
Welcome to Reap Automotive Design I assume they will be a bit cheaper on the post!
'95 C4 RSRs, Cargraphic sports cats, Turbo PU, Techart fog/brake ducts |
