door wont open with lever inside
door wont open from passnger side .took the card off but the bar had popped off at the lock end tried for a couple of hours but just couldnt get my hand inside and pop it back on is there an easier way
Old 01-11-2021, 04:26 AM
If the rod end popped off, the linkage clip is probably broken. You will need a new door lock clip Part#993-531-563-00-OEM. It's a tight spot so small hands is an asset here.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 01-11-2021, 05:37 AM
would it be easier to loosen the lock unfortunatley no small hands
Old 01-11-2021, 07:19 AM
You may need to remove the door lock assembly item #24 and push both rods into the clip item #23 before putting it back in.
Old 01-11-2021, 07:53 AM
i think your right as i cant get my hand in the small space and pop the clip in
Old 01-12-2021, 01:20 AM
Yes, only three M6 oval-head screws outside on each door and catch it from the inside
Old 01-12-2021, 05:03 AM
well yesterday finally got it done . loosened off the door lock after borrowing a freinds impact driver .and undone the bolts of the window frame . it still took me over 1 hour to get the clip in straight without bending or breaking the lugs which hold it in . then clipping the bar in was another process of getting a screwdriver behind so the actuall holder didnt flex and finally that pop of the bar going in was almost as good as an orgasm . what a poxy poxy job . but done .thanks for the advice
Old 01-20-2021, 07:20 PM
