-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   What is the function of this relay? (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1081701-what-function-relay.html)
LCOX 12-25-2020 09:26 AM
I've posted a picture of the relay/fuse panel in the engine compartment of my 964.
What is the funtion of the tall black relay. The part number is 811 951 253. Thanks Lhttp://forums.pelicanparts.com/uploa...1608920947.jpg
budge96 12-25-2020 09:35 AM
Rear eng compartment relay
If I'm not mistaken that is for the rear auxiliary blower mounted on side of intake ...
Bert
LM964 12-26-2020 07:46 AM
Yes, it's the double relay for the rear blower. The other relay being for cars fitted with A/C (M573).
964TargaC2 12-27-2020 09:40 AM
It is the same relay used for oil cooler fan and AC condenser fan (both are in fuse box in frunk)
The engine compartment relay is subject to great heat and can fail..I have had to replace that and my oil cooler relay
Good idea to use contact cleaner when refitting these
LCOX 01-13-2021 09:51 AM
Anyone with knowledge of testing this relay with an ohm meter?
bazar01 01-13-2021 03:14 PM
It's a double coil/contact relay for a two speed blower operation.
Resistance test across first coil at 85 and 86 and second coil at 85c and 86. 86 is common.
Continuity test across 30 and 87.
Continuity test across 30c and 87c.
12VDC power test at 30 and ground and 30c and ground.
What seems to be the issue being resolved?
http://forums.pelicanparts.com/uploa...1610583057.jpg
David Victor 01-14-2021 12:21 AM
Thanks for the diagram for rely function!!!
LCOX 01-14-2021 08:31 AM
Bazar01. I tested the relay. Results below.
Resistance across 85 and 86. 74 ohms
Resistance across 85c and 86. 71 ohms
12 volts at 30 and 30c sockets at the wiring harness plug
30 and 87 had no reading on the meter when I checked for continuity. The same for 30c and 87.
12volts at socket 30 on the wiring plug
12 volts at socket 30c on the wiring plug
bazar01 01-14-2021 09:45 AM
LCOX, what electrical issue are you having with the relay and engine compartment blower?
LCOX 01-14-2021 04:14 PM
I can hear the relay clicking about 1 or 2 times a minute. The engine is stone COLD and not running. The engine mounted fan is not running at this time. I haven't driven the car and gotten
the engine up to operating temps yet. This may be draining my battery as well. That's the reason i wanted to check out the relay closer.
Car
bazar01 01-15-2021 05:07 AM
Ok. Can you feel the relay click aside from hearing it with the ignition switch off? No key in ignition switch?
