davisriley's Avatar
Antenna booster needed
Anyone have an extra they would be willing to part with? Broke mine last night. Pm we with details if you have an extra. Thanks.
1991 C4-edging further away from stock
1972 T-Incoming project
Old 02-19-2009, 10:51 AM
Where is that antenna booster located?
1997 Carrera S
Old 03-04-2009, 07:42 AM
davisriley's Avatar
Booster is located up underneath the windshield on the pass side. Best way to get to it is to take off the dash pads. Not so bad to get to it at that point. I actually found a booster, and have tunes again once more. Are you having a problem with yours?
Old 03-04-2009, 07:56 AM
Yes..., with mine the cable that goes to the radio is broken. So I bought an used one, but can't find the existing one. The other question is how do I get the pads off?
1997 Carrera S
Old 03-04-2009, 08:05 AM
davisriley's Avatar
To get the pads off, first take the vent panel off up by the windshield. There are 6 phillips screw in that, I think. After that, there are maybe 3 screw under that that hold the leading edge of the dash. There are 3 more fasteners to the dash panel. At either end of the dash there is a screw under a platic cover, and there is a hidden nut. To get to the nut, pull the clock out of the dash. The nut is to the pass side, right inside the clock opening. After that, the upper dash comes off. At that point you can see the booster. Good luck.
Old 03-04-2009, 09:25 AM
Thanks!!
I follow your advise, replace the booster and now I'm installing all back again!!
Appreciate your help!!
1997 Carrera S
Old 03-04-2009, 09:30 AM
davisriley's Avatar
Great to hear. Just let us know that everything is good when you are done.
Old 03-04-2009, 10:42 AM
