Diving in 911
964 springs
I have a late model 964 and I’m trying to figure out is 993 lowering springs will work on it. I know the suspension is different between them...but at the springs?
Thanks!
1976 911s Special Edition Turbo bodied IROC tribute 2002 911 Carrera C4S 1971 914 1.7 Tangerine 1989 964 Coupe/1992 964 Cab 1987 928s4 Granite Green |
Hi I have an early 964 c4 and have had the car for 30 years and went thru some set up but finally I found the best setup for all around 1st time I used the H&R Springs with Stock shocks and after few yaes my rear shock went bad and i changed them to HD bilstein but It was so stiff until my H&R sagged so much that stiffness was unbearable, so I switched to my OEM Springs that I kept and then the car became better but the gap was high especially on the front end and , recently found a best Mechanic in town that suggested me if I could find M030 that is the way to go and he was right on the money the M030 to me is the best ride of all that I tried , I hope that helps
your 993
What is M030?
Hi |
Look into Eibach PRO-KIT | Performance Springs
Performance Springs Top-Performance Handling Lower center of Gravity - Lowers Vehicle up to 1.5" Progressive Spring Design Precision tuned spring rates Excellent ride quality I very happy with these, not to stiff. I have them on my 964 turbo.
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
Thread Tools | |
Rate This Thread | |
