-   Porsche 964 & 993 Technical Forum (http://forums.pelicanparts.com/porsche-964-993-technical-forum/)
-   -   Help, cannot get my PS fluid to stop foaming (http://forums.pelicanparts.com/porsche-964-993-technical-forum/1086326-help-cannot-get-my-ps-fluid-stop-foaming.html)
yelcab1 02-17-2021 09:43 AM
I am trying to get the 1989 964 PS pump to stop groaning. I have pumped 4 gallons of fluid through the system and the output hose continues to pump out foaming frothing PS fluid. What am I doing wrong?
Resevoir is disconnected entirely.
Input to pump is connected to a hose and dipped into a 2 gal tank of Fresh PS fluid
Return hose is dipped into a 3/4 inch hose and dipped into a collection basket.
picture is of 4 gallons of PS fluid foaming.
\ http://forums.pelicanparts.com/uploa...1613583787.jpg
bazar01 02-18-2021 06:38 AM
That looks delicious !
Your set up is sucking air.
Change from a suction lift to a suction head.
Then crank/start the engine and let it run for a few seconds at a time (5 seconds maybe) then turn off. Then keep the container filled. Don't let the container run out of fluid. Do it a few times until the fluid stream is solid...
I'll just actually leave the reservoir connected and the return hose discharge to an open container.
Just run the engine a few seconds at a time not letting the reservoir get empty.
Fill it up then repeat.
If it still groans, the reservoir screen could be plugged up.
