Stripped Valve Cover Bolt
Sad day, stripped out lower corner valve bolt on drivers side lower cover. Can this be heli-coiled?
Tried to attach picture, but not sure it is working.
Thanks!
https://drive.google.com/file/d/1gNFUFjDKUxsD8vMOL9jzUq_VX6NcRLqt/view?usp=sharing
Old 09-04-2021, 11:33 AM
Newsboy's Avatar
Did you try running a die over it to re establish the thread?
Old 09-05-2021, 02:54 AM
Maybe try a longer 6mm Allen cap screw. 5mm longer?
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 09-05-2021, 06:09 PM
I didn't realise people removed the studs and replaced with bolts.. I guess they look nicer.
But there should be no reason why you cannot helicoil that thread. TAke the cover off, and go for it. 5 minute job seeing as it's already on your engine stand.
Always learning.
www.aircooledporsches.com.au
Old 09-06-2021, 01:31 AM
Time-cert is better.
As Mike mentioned, a stud is better as it is fixed and secured to the aluminum threaded hole. Everytime you remove the valve cover, the stud remains and there's no possibility of stripping the threads because you remove the steel hex nut that is mated to the stud.
Bad idea to replace the studs with cap screws.
Old 09-06-2021, 07:03 AM
Exactly, and also you get the benefit of a steel nut on a steel stud. As opposed to a steel bolt in aluminum threads.
FYI if planning on trying a longer bolt, the rule of thumb to prevent stripping of the aluminum threads is to have thread engagement that is equal to 1.5 times the diameter of the bolt.
So a 6mm bolt needs to have 9 mm of thread engagement if it is in aluminum.
If it is into steel then the rule is 1.0 times the diameter.
Old 09-06-2021, 08:25 AM
The engine Early 95 came with bolts not studs and I did get new ones as part of the top-end rebuild. Will try to retap with longer bolt since they are standard size (not always the case on this car, )
Thanks to all for the advice.
Old 09-06-2021, 05:28 PM
No was to despondent to do anything yet, :/
Old 09-06-2021, 05:30 PM
Cobalt's Avatar
993 has cap screws 964 uses studs with nuts. It is such a low torque value 9.7 Nm or just slightly more than 7 ft pounds. I have seen people over torque these which causes the leaks we are all trying to avoid. It is critical that you don't over tighten these down crushing the rubber seals and torque equally amongst all nuts or screws to prevent leaks.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 09-08-2021, 04:32 AM
Jeff Alton's Avatar
A helicoil will be fine in this low torque application. A timesert requires a larger hole put into the parent material, not an issue in this case either.... Don't waste time with a longer bolt. Fix it right. A few minutes of time.
Cheers
www.turn3autosport.com
Old 09-27-2021, 08:05 PM
#147 of 2096
I have done a few,
time cert is the way to go.
#147 of 2096
Old 10-13-2021, 09:19 PM
