Brake balance
on my 964 turbo with the same brakeboost setup as the C4
i dont like the feeling for track use,
the pedal has way to much brake boost assistance, is there any way to modify that?
and the bias balance is not what i like, i have taken away the restrictor to rear brakes so just straight pipe but it is still to little rear brakes for my driving taste, and front is abs aktive way to easy.
what is the best modify for that?
https://youtu.be/UFYLfIcnero
Old 10-27-2021, 08:23 AM
bumpsteer on original hub
has anyone manage to build a new toe rod to minimize the bumpsteer on a lowered 964 with original steel hub?
i see there is a kit from elephant but i think i would be possible to make something that gets closer to the hub, to mount on other side might be to much.
i am thinking this must have been tested before here on a real trackday car?
Old 10-27-2021, 08:29 AM
