911Vintage
1995 993 timing chain housing
I just got my 993 back from an oil change and it's leaking like a sieve! I know that it had a leak from the timing chain housing but only a few drips. Now it's leaving a streak when I pull away and when I park it's leaking a lot more. Leak stops after a minute or two of driving then resumes when parked. The estimate for the reseal was $4600 so I just lived with the few drops. Did they overfill or do I have to bite the bullet. is the estimate fair?
Old 09-23-2021, 01:17 PM
Did you check to make sure it’s not coming from the drain plugs? Any other changes from last change to this change like a different oil or viscosity?
The timing covers are a known weak point and if the leak is isolated to the covers you can have this done for much less without dropping the engine. On my Targa the timing chain covers started with a slow seepage which stayed that way for 18 months. That developed into a few drops and I lived with it but then it started leaking in earnest 8 months later and I bit the bullet and had them resealed. Fortunately nothing else was leaking.
CURRENT:
2011 Boxster Spyder, Sport Buckets, MT, Full Leather, PSE, Basalt Black/Black
1990 964 C2, MT, Marine Blue, Silk Grey/Marine Blue
2024 Macan White, Beige / 2010 Cayenne White, Black
PAST: 69 911 Targa, 87 928 MT Marine Blue, 90 928 GT Marine Blue, 90 911 Targa Stone Grey
Old 09-23-2021, 06:04 PM
Having just resolved the previous owner's overfilling with oil, I can tell you that my C4 leaked a lot of oil until I drained it and properly filled it to the correct level. I was amazed when all leaks stopped.
I would check for overfilling first.
Old 09-25-2021, 07:36 AM
Cause & Effect, immediate post oil change by someone other then yourself, check the oil level. Too many "wrench" use the dash level gauge and do not wait for the engine to warm up. Filling up 9+ quarts with the slow fill rate of a air cooled 911 can cause "wrench" to cut corners / lose track of how much oil they took out and put in. Especially if not using / counting quart containers, using a shop fill hose of 5gl jugs.
97 993 RSCS Tribute (Poliezi)
96 993TT (Yel/Blk)
17 AMG GLE 43 (Blu/Blk) - 08 smart fortwo (Yel/Blk) -99 JD F 911 (Grn/Yel)
89 944 T (Blk/Wht) sold
Old 09-26-2021, 05:08 AM
Cobalt's Avatar
If your timing covers are leaking that badly I would not drive it. Although I agree with others could be overfilled which is bad and time for a new shop or could be they tried to fill it all at once quickly and it backed up the filler neck and left a mess of oil in and about the filter slowly dripping down as you take off. Again time for another shop.
$4600 seems excessive for the timing chain reseal at that rate drop the engine and reseal everything. It shouldn't cost much more.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 09-29-2021, 05:52 AM
It’s a pain to do without dropping the engine. If you’re in need of a new clutch in the near future this could give extra motivation.
Old 10-07-2021, 11:18 AM
midnight911's Avatar
I replaced the timing chain cover gaskets. Easy DIY. No need to drop the engine. But it shouldn't leak that much from the cover. If it is leaking that bad, it should be very visible. Since it's after an oil change, I suspect the small oil filter just in front of heat exchanger on the passenger side. If it's loose, just hand tighten with a slight force.
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 10-07-2021, 10:26 PM
I wouldn't exactly say this is a easy DIY. Did you remove the AC bracket? You'll have to pull the crank pulley and half of the rear end of the car apart. Do you have a DIY you followed? Thanks
Old 11-17-2021, 06:17 PM
911Vintage
so I replaced the valve covers with billet Aluminum and it pretty much stopped it. I don't let the car warm up too much and I drive it below 3000 rpm until temp comes up a little.
Old 01-12-2022, 05:12 PM
